Repair iTunes could not connect | How to connect iTunes
aollogin
Anmeldedatum: 14.10.2019
BeitragVerfasst am: 07.11.2019 08:35    Titel: Repair iTunes could not connect | How to connect iTunes Antworten mit Zitat
At times, you might want to restore or sync your data with iTunes. To do this, the primary thing that you have to do is connect your iOS device with iTunes. However, in this situation, the users sometimes come across an error. The error usually reads as "iTunes could not connect to this iPhone because of an unknown error". Fortunately, there are certain ways to fix it. The first thing you can do is uninstall any third-party software available on your device. If this doesn’t work, you can refresh iOS services or reinstall iOS USB Driver. You can also iTunes alternative if none of the earlier methods work. You can also go for these options if you are unable to reset MacBook Pro or reset mac computer.
How to uninstall
How to reset
Aol gold support
Benutzer-Profile anzeigen Private Nachricht senden Website dieses Benutzers besuchen AIM-Name
